My first Crown
After mushing the end of a felt tip I switched to a pencil. I always liked pencil sketches better :wink:
Don, that looks pretty good! Just a questions: What is the source of the “clicking” sound as it changes directions?
Looks so awesome!
I can’t wait for all the parts to print so i can start making my own crown! :joy:
You guys are getting me all jealous!
You had me worried I needed to go back and run it again.
The iPhone was just above the cables that use the Tape Measure Trick to keep the cables elevated. You are hearing the tape measure flex as it is forced in a different direction.
Most of the clicks are pretty minor until you put an iPhone 2”s away from the bend in the tape.
Well…to get that with a pencil and not break the tip…ummmm good job! You are already at like level 4 with that stunt!
Congratulations Don.
Looking great! I bet you are looking forward to making chips next!
Or ordering a laser.
I also turn wood bowls thought it would be neat to laser sign my name on the back and/or engrave the inside bottom.
I want to eventually try a laser on some turned pens.
