Here is my Primo with mini-RAMBO. I printed the crown file with a Sharpie taped to the core and it worked so now I am modifying the Dewalt 660 tool holder to fit my Craftsman rotory cutter.
Now I will try some simple milling in scrap wood.
Cool
Congrats.
Where in Nova are you? I grew up in Oakton and now live near Fredericksburg. I just ordered the last parts to finish my Primo. So hope it works as well as yours!
I’m in north Stafford.
Looking good
I’m so jealous
I needed to see this to help me get moving on finishing mine! So thank you
So I have tidied up all the wires and covered them with wire looms. I still need to print the housing for the control screen, but I am having some issues with my 3D printer now, and work and health issues are getting in the way a bit.
Overall the machine is working well and I am getting more comfortable with EstlCAM and Inkspace but I still cannot get things to always work as I envision them.
I also do not have the correct tool mount for the Craftsman roto cutter I am using so I modified the mount for the DeWalt 660 for the bottom using TinkerCAD and zip-tied the top. If anyone has a file for the proper mount for this tool I would appreciate it if you would share it. (I have been using AutoCAD for at least 20 years but it has always been 2D drafting and patent drawings so 3D is difficult for me.) Also, how far down should the collet of the router be from the bottom of the z-axis rods? I have not seen anything specifying that as most people seem to use the 660 and the mount on the MPCNC site so it’s already in the correct position.
I love that purple stuff!
Not really sure why it missed some of that stuff in the owl. Maybe on that section you didn’t set it to a wide enough clearing in the settings. When you see the screen make sure the red circles all overlap. You can go as wide as you need.
I think the problem is since I don’t have a proper tool mount (using zip ties on too) there is movement in the tool. It will get better as I design and print the mount.
Since I could not find a tool mount for my Craftsman rotary cutting tool I designed and printed one myself using TinkerCAD. https://www.thingiverse.com/thing:4854350
So far it works well but I will update it if changes are needed.
