Any carbide create gurus that could make the attached file into a dfx? shoot me a message what you would charge to create the file.
Thanks
Jason Dewester
7-Inch-Soap-Dish.pdf (84.4 KB)
Thanks
Jason Dewester
How about an svg? Converting images (even PDFs) to svgs is easy with inkscape. I opened it in estlcam just to be sure.
You’ll have to scale it.
7-Inch-Soap-Dish.zip (90.7 KB)
Is this any good for you Jason, it is drawn in metric.
Rename the file extension to dxf
Soap-dish.txt (83.7 KB)
Thanks guys for the help I just need to figure out how to scale it to size in estlcam.
In estlcam, View, Grid, X 25.4 Y 25.4 . This gives you a grid of 1 inch squares. Now you can scale up or down to the squares. You can also hold the middle mouse button on an edge line and draw a measurement line to the other side, have to keep holding, or it goes away, but a quick way to check.
Hi Jason, did you fix that ? As i understand you right you need a dxf file use in estlecam.
If you like i can make that for you, just for fun. I like this pojekts to build it in fusion 360.
If you like - give me a message and i will do it.
Best regards
Marcus
p.s. I use also Estlcam and the MPCNC
