I can get an end stops to work and home x,y and z as minimums, but I can’t get it to call Z max home, which is what I want for z. I did un-comment a line to make Z max active and I can get marlin to report back that it is “triggered” when closed, so I know I have it wired to the correct pins, but try as I might, I can’t get Repetier to home Z at max. I wire it up and set everything in Repetier as I think it should be and when I press “Home Z” it starts going down, not up.
I have since re-flashed Vicious 1’s new/fixed RC8 fresh so all settings are stock.
Beginning with that fresh version, what do I need to un-comment/alter in the firmware to get this to work, and what settings do I need to set in Repetier.
Any tips are appreciated.
And any ideas for mounting the endstop for Z max would be great.
