mounted on the table. angle iron base with corner height adjustments. the couch and armoire must go. I need to rotate 90 to move the cable chains to the back.
Looking good so far. The heavier tubes will likely mean you won’t be quite able to pull the fastest speeds out of it without mucking a bunch with acceleration and jerk settings, but as long as you keep to sane speeds it should work just fine.
