started the build today, should finish tomorrow
Do you already have the table built? What will you be making with your rig?
Did you get it done in one day?
no i would of done but i threaded a nylon nut it got stuck and removing it i broke the yz roller, just waiting on another one to be printed, and a good tip is make sure you buy 100% threaded bolts as the m8 i bought didnt fit because the thread is m8 and the rest of the shaft is m9
hi fellow UKer,
where did you get your ally cut?
cheers
