I’m also new to 3d printing as well… Turns out masking tape was a bad idea. I’ll try hairspray for the next piece.
I’ll be printing on a CR-10 (bowden tube style) in Hatchbox PLA. I’ve settled on Cura as my slicer for now. Running 0.2 layer height and 0.5 extrusion width, 3 walls and top/bottom, linear infill pattern, 40 mm/s print speed, 3.5mm retraction @ 40mm/s (microswiss hotend). Any comments or suggestions on these settings let me know!
There is something specific in the brand name blue tape that works better than plain brown, and the hairspray is a similar thing, it has to be a specific type.
I didn’t know that about the tape. This roll of tape actually came with the printer, all Chinese lettering and everything. The PLA sticks really well, too well. With as much surface area as this piece had on the build plate it’s just a PITA to get the tape off the part.
Based on my what I’ve read I’ll be trying some Aqua Net hairspray in the purple can.
That tape probably has the right stuff in it. If it sticks too well, you can soak it in alcohol in a tupperware and it will dissolve enough you can rub it off.
I have the same issue with blue tape. I use a sharpened spackle/putty knife to remove my prints. Carefully work the knife under a corner and you can lever the print up until it pops off.
Are you using the cura that comes bundled with repetier host by chance? If so it’s probably best to ditch the built in version before you get too invested in fine tuning. I ended up needing to use a standalone version of cura newer than what repetier ships with to fix some of my print issues. (Extra priming after retracts, specifically) I was having a hell of a time chasing under extrusion problems. I used a bottom of the barrel ANET printer though. YMMV
I’m using Cura 3.6 from the Cura website. I’m not having any slicer issues as far as I know. I was using Slic3r but had better prints with Cura for a few non mpcnc prints I was doing so I’m just rolling with it.
@Ryan, can you tell me the difference between the roller and rollerM parts? I can see one difference in the shape of the inner bearing “wheel well” but I can’t figure out how they’re functionally different.
IDK, Ryan’s pretty serious about reducing part counts (including part types), so I’m sure there’s some reason. I guess we’ll have to wait until Ryan responds.
