Ok so some have been asking what changed in the config files. So i spent some time going back thru the files comparing to see what all I changed, and I think this is it .
listed below are what i changed ONLY those files. This complied for my build setup.
LOWRIDER2 CNC BUNDLE without motherboard purchased from RyanV1 (you did an amazing job sir!! i thank you !!!)
SKR V1.4 TURBO
SKR TFT 3.5 E3 V3.O
TMC 2209’s
Dual Endstop on Y & Z axis
single endstop on X axis
MARLIN 2.0x
----BTT SKR 1.4 TURBO—
marlin 2.0x file
----------------------------------CONFIG.H*-------------------------------------------------------------------------------------------------------
#define STRING_CONFIG_H_AUTHOR “(CRASH13 SKR V1.4 TURBO TFT35 E3 V3.0 06-13-20)” // Who made the changes.
#define SERIAL_PORT -1
#define SERIAL_PORT_2 0
#define BAUDRATE 115200
#define MOTHERBOARD BOARD_BTT_SKR_V1_4_TURBO
#define CUSTOM_MACHINE_NAME “V1 LR2 CNC”
#define EXTRUDERS 0
#define DEFAULT_NOMINAL_FILAMENT_DIA 1.75
#define TEMP_SENSOR_0 999
#define USE_XMIN_PLUG
#define USE_YMIN_PLUG
#define USE_ZMIN_PLUG
#define USE_XMAX_PLUG //UNDEFINE
#define USE_YMAX_PLUG //UNDEFINE
#define USE_ZMAX_PLUG //UNDEFINE
#define ENDSTOPPULLUPS
#if DISABLED(ENDSTOPPULLUPS)
// Disable ENDSTOPPULLUPS to set pullups individually
#define ENDSTOPPULLUP_XMAX //UNDEFINE
#define ENDSTOPPULLUP_YMAX //UNDEFINE
#define ENDSTOPPULLUP_ZMAX //UNDEFINE
#define ENDSTOPPULLUP_XMIN //UNDEFINE
#define ENDSTOPPULLUP_YMIN //UNDEFINE
#define ENDSTOPPULLUP_ZMIN //UNDEFINE
//#define ENDSTOPPULLUP_ZMIN_PROBE
// Mechanical endstop with COM to ground and NC to Signal uses “false” here (most common setup).
#define X_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop. false
#define Y_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop. false
#define Z_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop. false
#define X_MAX_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop. false
#define Y_MAX_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop. false
#define Z_MAX_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop. false
#define Z_MIN_PROBE_ENDSTOP_INVERTING true // Set to true to invert the logic of the probe. false
#define X_DRIVER_TYPE TMC2209
#define Y_DRIVER_TYPE TMC2209
#define Z_DRIVER_TYPE TMC2209
//#define X2_DRIVER_TYPE TMC2209
#define Y2_DRIVER_TYPE TMC2209
#define Z2_DRIVER_TYPE TMC2209
//#define Z3_DRIVER_TYPE A4988
//#define Z4_DRIVER_TYPE A4988
#define E0_DRIVER_TYPE TMC2209
#define E1_DRIVER_TYPE TMC2209
//#define E2_DRIVER_TYPE TMC2209
#define DEFAULT_AXIS_STEPS_PER_UNIT { 100, 100, 400, 100 }
#define DEFAULT_MAX_FEEDRATE { 120, 120, 30, 25 }
#define DEFAULT_MAX_ACCELERATION { 400, 100, 100, 2000 }
#define DEFAULT_ACCELERATION 400 // X, Y, Z and E acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration for retracts
#define DEFAULT_TRAVEL_ACCELERATION 400 // X, Y, Z acceleration for travel (non printing) moves
#define S_CURVE_ACCELERATION
#define X_BED_SIZE 1200 //200 or 1000
#define Y_BED_SIZE 1500 //200 or 2000
#define EEPROM_SETTINGS // Persistent storage with M500 and M501
//#define DISABLE_M503 // Saves ~2700 bytes of PROGMEM. Disable for release!
#define EEPROM_CHITCHAT // Give feedback on EEPROM commands. Disable to save PROGMEM.
#define EEPROM_BOOT_SILENT // Keep M503 quiet and only give errors during first load
#if ENABLED(EEPROM_SETTINGS)
#define EEPROM_AUTO_INIT // Init EEPROM automatically on any errors. //#define EEPROM_AUTO_INIT
#endif
#define SDSUPPORT
#define INDIVIDUAL_AXIS_HOMING_MENU
#define SPEAKER
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER ( FOR THE TFT35 E3 V3)
