What is causing the endmill to make these cuts into the letters? i doesnt show this in the estlcam
Thanks for the help!
preview.
Looks like a flat or ball nose end mill being used for v-carving
You need the angle to be 180 degree for a regular flute mill. I can’t see your setting from this screen, but this is how it looks for me:
ok thanks, ill give this a try.
Carve tool path works best with v bits that is what the extra lines are ment to be cut with. The flat cut can be made with a box around the text and cutting a island using the pocket tool for the text to be raised
This is correct. Using the “hole” and “part” options would w.
I think i got it, ill try to do an actual cut and see how it turns out, thanks for the help. Btw I selected pocket outside within the text tool under the style menu.
I’ve not used the text tool much i do most of that in inkscape and import the svg and work from there. It looks like your getting a handle on it though
