In the lasts weeks I was learning a lot of cnc, milling, and mpcnc itself. Also CAD and CAM with Fusion 360. I was playing with fusion posts processors (a kind of javascripts plugin that write Gcode from the CAM operations), and in order to learn more, I decided to write one posts processor from scratch, taking some great ideas from the other posts processors and from users suggestions in the forum.
Right now I’ve a version that I was using in the last week to laser cutting/engraving and 2D milling (sorry, not 2.5D milling tested yet) without issues.
Some design points:
- Setup operation types: Milling, Water/Laser/Plasma
- Only support MM units (inches may work with custom start gcode - NOT TESTED)
- XY and Z independent travel speeds. Rapids are done with G1.
- Arcs support on XY plane
- Tested in Marlin 1.1.0RC8
- Tested with LCD display and SD card (built in tool change require printing from SD and LCD to restart)
- Support for 3 different laser power using “cutting modes” (through, etch, vaporize)
Please, have in mind that it MAY have bugs and/or errors, please take with care. It’s a work in progress, I’ll be adding functionality as my next projects (tool probe for example) need them, or new ideas comes.
I’ve published it in github if you want to fork/collaborate:
mpcnc_posts_processor-master.zip (4.89 KB)
