I am trying to come up w/ a good way to store my mpcnc in a way that will be quick/easy to deploy.
This is what I’ve come up with so far.
Using 2 vertical rails, the mpcnc would slide up against the wall (similar to a garage door rail).
The other (bottom when parked) end of the mpcnc would have rollers to help it slide across the workbench. when parked up on the wall.
I would have a pin on the rail as well as a hump for the bottom rollers to seat into (to make sure it stays vertical).
Anyone see any issues I may come up against?
Has anyone already done this?
any suggestions?
*I need it to push out further from the wall to make room for that side’s belt, and figure I can solve that by having the rail wheels further out than the belt.
*I don’t get to build it until later this summer, but would like to have plans together…depending on how fast construction goes on the house/garage =
[attachment file=“31438”]
