My 24x48 useable area, LowRider2 is slowly coming together.
Fun Sized, just like my current build. Nice.
I think there’s something wrong with your crown.
That looks like a nice clean build. Nice work.
Got a good crown with a MPCNC LowRider2.
BooYah!!! Looks and sounds great.
I have no idea where the other two comments went…
Figuring out a spoilboard gcode.
Make your model of the spoil board about an 8th inch bigger than the board really is. I had to go over one side of mine with a plane to get a sliver of unmachined mdf off.
What pen holder are you using? How did you attached it?
Peter
Peter
I used a Sharpie between two sponges. With two zip ties around it. I put the sponges in the router base. And put a round tool on top for weight.
I used a 1" spoilboard bit to surface the mdf.
Looks like you’re making good progress. That should really make the jobs go smoother.
FYI, you can make all these updates on a single build post.
What settings did you use? Surface speed, depth of cut, etc? Also, what speed setting was your router on?
I used a website to generate the gcode. They are no longer in business.
Lame question: how did you mount the clip that’s holding your LCD monitor/controller?
There’s a clip in the thingiverse files. Gets zip tied to the frame.
