I have installed the Dual End firmware.
The steppers are working in the correct direction.
The End stops show triggered when they are pressed using command M119
The Y axis and switches work great.
But when the steppers run into the X axis switches. It doesn’t make them stop.
If I send the X steppers to home and they hit the End stop switch. They keep moving.
The X and X1 Switches are wired just like the Y and Y1 switches.
They are set to NO until they are pressed.
I have tried to wire the X switches to NC and send to the home position.
But they don’t stop when triggered.
I have even moved the switches around from the X and Y location on the Ramp 1.4 board to see if it is the switches.
Its only the X and X1 location on the board. I think
Its almost like the software doesn’t know what to do when the switches are triggered.
I am using the Dual End stop firmware from V1.
What am I missing here.
My goal is for the Auto Squaring.
Acts like on one side it will be great to have.
I have to Ramps 1.4 cards and Adrino cards. The both do the same thing.
I am using the send to Home position to check this.
I am Using Windows 10.
I have 2 sets of Ramps 1.4 and Adrino cards. First set is from V1 and the other are identical from someone else.
Use repetier issue the m119 command and look at the output. They only do something to the machine while you are homing to prevent accidental issues we had early on. Using M119 is in the instructions page for dual endstops.
I just noticed something.
Everything is wired the way you wanted it.
But what I noticed is Y and Y2 work great.
X and X2 dont.
Could it be M119 show Y_min and Y2_min
But M119 shows X_min and X2_max.
X and X2 is the problem.
I have a min and min for Y
I have a min and max for X
20:37:06.858 : N14 M119*31
20:37:06.863 : Reporting endstop status
20:37:06.863 : x_min: open
20:37:06.863 : x2_max: open
20:37:06.863 : y_min: open
20:37:06.863 : y2_min: open
20:37:06.866 : z_min: open
20:37:06.866 : ok
