Hello, I purchased the kit from here including the wiring.
Here’s what I did so far
- Downloaded the Arduino IDE 1.8.0 software on my Windows 10 X64 as per instructions. IDE fires up OK.
- Downloaded and installed Repetier Host software. Configured the Printer setting per instructions. Had to change the COM5 port to 115200 speed as Repetier complained about the 225000 (?) speed. I can connect to the printer.
- I didn’t flash nor do anything with the ramp stack since I purchased it all from here.
- I plugged in the X, Y, Z to the controller keeping all the BLUE cables lined up.
- I installed the resistor to T0 as per instructions.
Here’s what it looks like:
- I have solid green LED on the bottom board.
- In Repetier Host, the log only shows: No Start signal detected - forcing start"
- When I use the MANUAL tab to try to move the steppers, I only get incrementing “Command Waiting” as can be seen here:
There is no humming or vibration from the steppers. Any idea where I can start the troubleshooing?
Thank you
Hansang
