Hi everyone,
So I have a larger MPCNC (600x600x80mm build volume.) When I was pocketing with a block machining operation from Estlcam, I noticed that parts of the pocketing of the gap was not cutting out all of the material, there were lines of wood left in the gap area.
Realizing this might be a misconfiguration of my steps/mm, I checked my GRBL config. I have my steps/mm on my 96oz steppers at 100 steps per rev, as that’s what the calculators pop out for the right value when I account for my belt and pulleys, etc. I don’t use a RAMPS board for controlling; I have external stepper controllers for each high-power motor.
I made a new test object, a 50x50x12mm box, and I configured Estlcam to cut that box and have a 30mm gap around it so that I’d have plenty of space to measure and see the problem in action. Motion in the direction where the gantry moves on the lower crossbar is dialed in perfectly. 50mm on that axis (my Y axis) resulted in a box side of 50mm through the entire length of that axis on the test cut.
Motion on the upper crossbar, however, produced a wiggly, variable cut length between 43mm and 45mm. At no point was the side of that box ever 50mm. I also noticed the same banding in the gap area. I used the caliper to measure the width of those bands of uncut wood and they were between 1.3 and 1.8mm thick.
At this point, it seems like something in my motion system is loose. I think the z-axis could very well be loose, but I’m wondering if there’s any other place in the build that might contribute to this wobbling.
Has anyone had to diagnose similar issues, and if so, what was your fix?
Thanks in advance,
Pete
