After building a much loved MPCNC, I’ve decided to build a lowrider.
Does anyone know of a good lowrider suitable mobile workbench kit (4’ x 8’) I could buy or a good set of plans for working with sheets of standard dimensions from big box home improvement stores? My current limitation is that I don’t have a table saw or current work bench to build a new work bench easily/properly.
When I was debating between the MPCNC and the LR2 I was also looking at table designs. I like the idea of using some iron square bar or something similar and attaching that to a table as the runners for the LR2 to run along. Something hefty, stable and STRAIGHT. But since I went with the MPCNC first I didn’t get very far with the plans beyond images in my head.
Check out the local Habitat for Humanity Restore. There are often hollow core doors that can work for tables. You might even be able to find a larger size or use a couple and connect them.
This might give you some inspiration. Could be done with a plain circular saw but better with a track saw.
