Could I use an original rambo for a mp3dp build?
I’m not sure what you mean by original. The big (not mini) rambo? The Rambo 1.3? Something earlier?
We have a rambo configuration for the MP3DP in MarlinBuilder releases.
The one from a rostock max v3 all it says is rambo
It looks very similar to the one I used in the primo.
It even uses the same lcd adapter
Do you want to share a pic? It is worth a shot.
I did a bit of searching. I believe this a Rambo 1.3 board based on my searches. The only difference between the Rambo 1.3 and 1.4 is a servo pin, so the V13DP_Rambo-2.0.7.2-src.zip should work.
I knew there were subtle differences and I didn’t know how many variations there are.
Thanks for the help. I’m probably going to upgrade the rostock to duet 2 wifi and build an mp3dp with the rambo.
It sure looks like the 1.3. The only difference to the 1.4 is that lcd adapter board isn’t needed on the 1.4. I trust Robert that the pins file also moved a servo pin. But the firmware does work on the 1.3.
Yay for more printers!
