The parts page says only one spacer is needed, but as I’m about finished with everything it seems like I need two. Can someone tell me how many I need?
If you are using T8 then you can use two (or one spacer and the nut trap). The nut trap serves as the second spacer if you are using standard all-thread.
Ok I’m using the T8. Thanks.
