I have to order a low rider kit that I need to build for long format
can you help me with the right BOQ so I am not going to make mistake processing my order. this what I have understood that I need to process at least.
LOWRIDER2 CNC BUNDLE no board
RAMBO V1.4
LOWRIDER2 CNC PRINTED PARTS 25MM
FULL GRAPHIC SMART CONTROLLER, BIG
I will buy the router locally in Europe later when all the machine will be assembled
and for the Low right flat part, I will produce it my self with a friend.
I need to make a system at least 3 meters long so do I need extra GT2 10mm Belt?
I would like to build a frame with 4 horizontal tubes in a state of just 2 because I need very right design so can I have extra plastic connectors for this scope?
Why not the mini rambo? The full is fine but for most unnecessary.
Always buy your rails first to verify the dimensions.
Yes.
You are on your own for this one. You should be fine as is, for milling wood and plastic, if you plan on doing anything other than that 3M is a probably not a good idea.
Ok… i take you suggestions… let move forward with Mini rambo and about the tube 25mm i check already and these are what are available from some company near me.
could you please update my order and include extra GT2 10mm belt at lear for 3.5m long Lowride.
