Is there a way to change the orientation of the design when shown on the grid in Repetier? I am using a laptop rather than an LCD. My MPCNC is on a table that is in a corner and attached to a wall and can’t be turned. When the spindle begins cutting, it is cutting the design upside down and apart from unscrewing the legs from the MPCNC and turning it, I can’t find another way to orient it correctly. I read that in Repetier you can right click on the design to change the orientation, but that did not work when I loaded a .dxf.
You can turn the DXF or just flip the stepper plugs.
Have a look at the “Testing” section. https://www.v1engineering.com/assembly/software/
