I suppose I could make plans available for a (phe)nominal fee.* 8^)
There’s a couple little details I should probably fix first, if I’m going to share. In particular, the feet were a total after thought. I realized immediately after assembling the first one, that feet of end grain plywood were destined to get destroyed. I drew up feet that fit the rear legs great, but the front legs taper right to the bottom, and I was too lazy to account for that. My quick and dirty fix involved a hand saw, but I’ll correct it in CAD before sharing.
I started work at 0300 this morning, and I’m feeling a bit stretched at this point, so give me a day or so to fix that…
Also, there’s a couple of bits not drawn up in the CAD. Cleats for the seat bottom to rest on and the bar for the adjustable seat back, both of which I just cut on the table saw. It might make sense to add the seat back bar to the CAD…
I did the CAD/CAM in FreeCAD. It looks like I could export .svg, .dxf, .stl, etc. What would be the best format to share? I used a variable to account for material thickness (~18mm), and the width of the slots and length of the tabs used for joinery reference this, but I think just scaling EVERYTHING to account for thickness variation should work…
- I can’t see actually charging anything…might have to figure out how to accept tips or something. I’m open to recommendations in that line…I have a paypal account, and Thingiverse has some sort of mechanism…
