Yes, it’s called FR4 (it’s essentially copper foil on top of fiberglass.) that’s where tiny fractions of a mm in leg height would cause issues. My cut depth was only .03mm.
Have you ever tried eagle camsoftware with flatcam?
The workflow is:
Eagle->gerber(and excellon)files->flatcam->gcode.
It seems to be a little complicated but is not. You just need to invest 2days for learning and you are good to go.
And after all you end up with the knowledge that lets you make make proffesional pcb’s,prepare gerber files in case you want send your board to any pcb factory.
Perhaps I’ll show some pcb jobs from my machine, when I get to my workshop.
John,
maybe you can share the spindle speed vs feed-rate you are using. And maybe bit types for milling the board cutout and etching layers?
regards
Dev
spindle speed is “whatever the router provides when it’s turned on”. I haven’t built any control for that yet. speed is fairly slow, but I don’t remember specifically what I set it to.
I’ve recently retired fritzing for sprint layout and the world is a much better place.
the workflow (most recently) is: Sprint Layout -> EStlcam (mill outside the line) -> gcode.
I posted the next board I created using this method and it’s significantly better than the first.
I’ve built a couple circuits in Eagle and just haven’t spent enough time to really get to know it. Sprint layout on the other hand, took me about 30 minutes to get pretty good at. plus, I have the addition of someone nearby that is also very good at sprint layout.
