Going to order some PET braiding wire wrap. Since it expands and contracts somewhat, what size to you use?
For what? For me it depends on how anal you want to get with it. If you are going to pull the plugs off things to feed it through you can go really small. The stuff I use the most I put in the shop it’s 3/8", https://vicious1-com.myshopify.com/collections/parts/products/wire-sleeve, I cram everything through tthat with the plugs on.
Ha, searched the forum for the info… never thought to look in the shop.
Thanks!
