Assembling my MPCNC right now, I noticed the X-Pipe of the gantry rotates when the gantry moves. Please see pictures attached.
It’s only slightly and barely visible in those two pictures. But you can see, the “X” will move a bit vertically when the gantry moves. The pipe is twisting/rotating.
- Is this a problem?
- If so, how to solve it?
Once the MPCNC is fully assembled, this pipe will probably be held in place, however, if there is some force, this doesn’t look like a solution for the pipe twisting, force would be applied to the bearings or something else and wear out, I guess.
I reassembled the gantry but can’t find anything bad, cracked or misaligned.
