I see, guess I’ll have to shorten the cables then
New small update.
I have made the internal wiring for endstops end steppers, and fitted the sockets.
Small update again.
Made some brackets and rails to fit the cabelchain on X/Y axis, and made brackets to fit the cabel chains to the steppers. I didnt find any i liked on thingiverse, so idesigned my own.
All stepper cables will be terminated with plugs:
3D printed brackets for fitting cable chain to steppers:
Cable chain fitted on X-axis:
Stepper wiring connected for both X-axis steppers.
Endstop wiring to go:
Long time no update (again)
As we are closing in on christmas season i figured i should get it up and running again.
Finnished terminating the plugs for steppers and end stops, end connected the end stops. The display seems to be broken, as there is missing lines no matter how short the cables are.
Also I have an issue with the endstops as shown in the below video. When triggering the endstops manually, everything works, and the end stops are in the right loctions. If I run the steppers to trigger the endstops they trigger, and if I then home the Y axis it is working like it should. However, if I run the Y axis 50mm from the endstop and then home the Y axis, it hits the stops and the steppers keep going. What could be causing this?
Is it possible you have the Y1 and Y2 endstops swapped?
I dont think so, as I tested all end stops one-by one manually. I think everything was correct by the labelling then. Of course i could have swapped the stepper cables, that i havent tested. Can the steppers be tested individually from repetier host?
Could it be that the firmware has a bogus workspace size set, and after 50mm, it’s off in never-never land? Usually, it just assumes it ran out of room and quits homing, but I suppose it’s possible it’s giving up on homing (thinking it’s run out of workspace), but never turns off the steppers. This seems odd, since the default firmware workspace size is certainly larger than 50mm, but it’s a thought.
We’re double posting here. Let’s just solve this one in your thread specific to this issue:
Agreed, posted a seperate thread as I didn’t think I would get a response this quick in an old project thread (you guys proved me wrong). Problem solved now though (swapped stepper connectors on main board), so thanks
