Pocket shallower than depth per pass?
Will EstlCAM use a more shallow depth if, say, my depth per pass is 5mm, but the depth of the pocket is only 2mm? My Lowrider completely demolishes pine (in a good way) and I’d like to reduce the cutting time by increasing the depth per pass, but I still have a few pockets I’d like to cut that are more shallow. Can I just increase the depth per pass and EstlCAM will lower it for those pockets automatically, or do I need to set up a different tool in it to make shallower cuts?
Yes. It won’t cut deeper than your pocket depth, even if the max depth per pass is deeper.
Perfect, thanks!
