To create it smallest possible, Y axis rails will be hinged on middle and “traverses” will be 3 wooden boxes which can be used as packing box for LRII itself.
Just for imagination, added quickly modeled sketches below.
I’d like to build something like this, do you dimensioned plans for it that you’d be willing to share?Also, what are you planning to do for supporting the table, especially if the surface isn’t even/level?
I think its a great idea, but you may get a bit frustrated screwing / fitting everything back into place each time you need to transport it.
I would try and extend on your idea a little to see if you can reduce the amount of ‘take apart’ (Well maybe this could be an ambition of mk2 once you’ve built this)
