I got an idea in my head I have to try. I bought a 1/2" cutting board that was 12x18" which is perfect to make 2 YZ plates from. It’s solid and doesn’t flex at all and was only around $16 on Amazon. It just arrived today so here in a bit I’m going to give it a whirl using a 3d printed YZ plate as a template. The only concern I have are the screws holding the linear rails as everything else is bolted through it.
Hey, great idea. I was just about to post asking if 5/8" plywood is OK to use for YZ plates, but after seeing your post here, I’m remembering I have quite a bit of 1/2" HDPE (black) lying around, most is large scraps leftover from a previous paying job, and there’s plenty to pick from for cutting YZ plates.
I’m still working on mine. Waiting on the board, drivers and screen to arrive this week. I think it will work pretty good, but just in case one of the first things I’m going to cut is a new set of MDF YZ plates to have as a backup.
I used 12mm acrylic, I’m quite happy with it. However, I did have issues with the linear rails binding - I haven’t quite figured out why they were binding, and have since just left the rails semi-loose while holding the screws in with Loctite.
A friend of mine suggested that laser cutting the acrylic plate did introduce a warp. I haven’t delved too deeply into it, as my LR3 is functioning.
Would this work for the XZ plates also? The reason I’m asking is I’ve wasted a good bit of plastic trying to print the XZ plates. I keep getting a layer shift and I’m not sure why. My Ender 3 printed a ton of parts really well so far including the core with no layer shifting. I’m wondering if it’s b/c of the 70% infill but I’m not positive. I’ll probably make a new post to discuss the layer shifting issue but I wanted to ask if this could work for the XZ plates b/c then I could just print the stub parts and mill out the XZ as I’ve got a V1 MPCNC Primo that I can use.
