I have been using an old version on Vcarve with the Ramps PP. This has giving me some trouble because the Ramps PP does mot support tool changes and some of my larger project have up to four tool changes. I have been getting a lot of job request lately for 3d relief work so we are adding ArtCam into our software collection but the Ramps PP is not supported in Artcam. Are there any other PostP’s out there that run well on our board specificly ones that support tool changing?
Chris, any luck finding a solution for this?
I came across this website (use Google Translate). Basically, you select “Hanter (.NC)” as the output format. Then Repetier-Host can read this – just tried it.
3Drag tutorial: from ArtCam to Repetier Host
http://blog.elettronicain.it/2014/01/08/3drag-tutorial-da-artcam-repetier-host/
