You still are not showing what files you are trying to flash, what is the folder name.
Did you install the u8glib? Show your sketch/include library drop down in arduino.
Are you using the board show in the first picture?
If you use that board this is wasted time, it is not made for that board at all.
Yes this is the board. Yes I installed U8glib. Here is the include library Pic. I’m not understanding what you mean by the files I’m trying to flash. I am following the instructions for MPCNC_Rambo_T8_16T_LCD like Jim and you told me to do earlier in the thread.
Sorry but my files are built for very specific boards, you will need to edit the files to work with that board, if they do. Some of those only work with GRBL.
Well… Poop. Do you know where I can get instructions on how to flash it with the GRBL firmware?
I just googled it, looks like it is a ramps clone. So using my Ramps (not Rambo) firmware should work.
Sorry about all the previous confusions I did not read through the whole thread each time.
No worries. I appreciate the time you took to help me out get this far.
