anyone have info on any additional hardware needs when transitioning to the Primo from the Burly build?
Will i need extra bolts, nuts, etc?
Also - has anyone attempted to anneal their PLA builds with a salt pack, or cast into plaster? seems like something we all may benefit from - especially those of use working with metal projects.
In addition, to this hardware, Primo uses 10mm belts instead of the 6mm belts of the Burly.
I’ve watched a couple of videos and the technique looks promising, but even minor shrinkage or distortion can render parts unusable. In places tolerances are tight.
