I have a MPCNC Primo with a dewalt dw660 mounted. I would like to mount a chinese 5.5w laser I have that came with the small 3018 cnc. It is a 5.5w - dimentions of the diode heatsink is 33mmx33mmx65mm. It has a 30mmx10mm fan mounted on the top and the laser lens protrudes out the other end of it. I suck at Fusion 360 so was hoping to find a solution I don’t have to bugger much with. I did print https://www.thingiverse.com/thing:4547573 but its made for a different dimentional laser - 32.5mm wide and the screw holes are different.
So I adapted the one I mentioned in my original post. A file and a bit of elbow grease and I have it fitting perfectly. My mistake came in wiring it up and promptly blew my laser driver board so now not needed I guess.
I’m either going to buy a new laser (maybe co2) or not at all for the time being.
