Printed leg posts
Am sure this has probably been asked but is there any reason not to print the 4 tube leg posts. Maybe do a solid bar type leg with 55% fill with 4 line walls, etc. These seem such short pieces for the recommended size ( 67mm? ) that I wonder if the plastic might be strong enough?
Trev
I would bet you will have the metal left over. You could print them maybe in two pieces but I would just stick with metal.
