This video (3 minutes, in 3 parts) is the first cut in wood (MDF).
First minute is timelapse (octopi) so it has got no sound.
Second minute is the examination of the part after the cut
Third minute is the spoil board and the underside of the cut board.
For what I am building this link will take you to the plans for the game.
Will post in this thread the rest of the parts and the final assembly of the game board.
for item 2 and 3 I used the same speed settings but for items 4,5 and 6 I increased the feed rates by 35%, 50 and 75% this decreased the cut time but the relevant print time.
Attached pictures of the 5 parts and the cut area’s. still some cleaning up on the parts of course.
The smaller parts (the 6 I cut above) if your dice land there is a 4x multiplier. the next tier up is a X3, next teir is x2 and the top teir is x1 (near the lip to teir 2) or x0 (near the initial roll area).
But score is not done until all dies are rolled for everyone. so you can (like the game bowls) roll your die to knock some one else off the board, and/or knock your own die to a higher scoring tier. but beware, you could knock some one else to a higher tier as well.
The die sets (same color for each player) I got are a D4, D6, D8, D10, D12 and D20. players can choose which to roll/when. I have 10 sets of different colored die, so the board (if 10 people are playing) should get really crowded.
The one rule for rolling die is that it must touch the rolling platform atleast once. so you can roll to it (like ping pong) or put the die there and flick it (like, soccer penality goal??)
I need to make 3 in all so they can be made into a tower.
Timelapse of the mill is at https://youtu.be/0kJW1C0CnWY taken with OctoPi at 1 frame per second. (and the camera was attached to the frame so thats the cause of the minor jitters).
Total mill time 4 hours 29 minutes.
For the floor seperators I will be using my 3D printer and some threaded rods.
The game in question is Burgle Bros. While the game can be played as shipped flat out on a table, there are already some add on you can buy from multiple designers that allow you to play like this in a tower.
Once I have this finished and assembled I will share the design on thingiverse.
Oh I got a 1/4 to 1/8 collet adaptor for the Ozito router, and put a dremel universal bit in.
Thats what I used for the Burgle Bros floor board cut. (and for the next 2)
Agreed using the original bit that came with the ozito was not the best, but at the time I didn’t have the new collet. now that I do I can use a number of bits I got from various sources (including a really nice 22 degree engraving bit).
I just bought Burgle Bros. Hasn’t arrived here yet though. Add this to my list of things other people are doing, that I should be doing instead of hounding the forums…
