Did you buy everything from here?
a)Did buy the Ramps from here, everything else bought somewhere else but the same parts as u described -
Are you using end stops?
a) No -
Are you using all my recommended parts?
a) Yes -
Include a picture so obvious errors might be spotted.
Hello, after several tests and setting up the extruder vref everything is running properly and without strange noises. The printer goes even in heights :). Still I got a problem and don’t know where to search it. It looks like there is not coming out enough filament. The nozzle is not jammed, do I need to calibrate the Extruder or am I missing something else? I use the test file and triple checked all slicer/ repetier host settings. See attached image how print is looking after aproximately 4 minutes.
