I put togheter my mpcnc. Now i should build the control and wire everything.
I tought to try just 1 stepper in the “air”. But it dont move.
I plan to use Estlecam with an arduino nano and tb6600 drivers.
As power supply i have 36v.
Now i connected the arduino nano with my pc and prpgrammed it. Seems to work so far.
Then I wired one tb6600 to the arduino nano as Z-axsis.
If i plug in everything the red LED on the tb6600 is burning and the green one is flashing fast. If i press z + or - in estlecam the green LED burns wothout flashing.
I choosed 1 microstep and 1.5 ampere on the tb6600.
My steppers are Nema17 Motor 59Ncm
Now if i try to move the Z- axis in estlcam nothing happens.
Im pretty sure i didnt understand something… Maybe someone can say why it wont work.
edit: I am using an Arduino Mega with the Arduinoclub board. But that should not matter.
edit 2: I could go up to 32k steps as you could, but it does not change much.
