Hello everybody,
I have a problem with my mpcnc and when it is in process it go wrong and everything is at final only a crap.
Sorry you didn’t really give any info to go off of.
These things should all be included in your post. It makes it much faster to diagnose problems.
Did you buy everything from here?
a)If you didn’t or changed some things please don’t leave out any details.
b)What firmware? -
Are you using end stops?
a)If so please disconnect them. -
Are you using all my recommended parts?
a) If not please list what parts you used. -
Include a picture so obvious errors might be spotted.
Sorry my bad…
I buy everything on ebay but all of parts are from list, firmware is yours with fg display, I dont use end stops and when I use laser and different software it works great. Is it a problem with estlcam? Maybe you can send me a good gcode to try it
There is test code in the estlcam basics page. It is probably your speed settings, start with x and y movements at 10mm/s and Z at 3mm/s see if that helps. If it does work your way back up.
