Problem (flashing Marlin firmware on Mini Rambo)
Hello to all the community here,
First of all I am trying to built the MPCNC project:
I am facing an issue with my mini rambo board (chinese clone probably), when I try to flash the Marlin firmware MPCNC_MRambo_T8_16T_LCD from the official github thread of Marlin.
When I compile & upload that firmware from Arduino v1.8.9 (tried also v1.9 BETA) and followed these flash instructions, it shows no errors, but the screen that comes with the board shows only 4 lines of white upside down y characters.
The button beeps & seems that it is moving inside the menus, but no movement coming from the steppers :-/
While, when I flash the same board with the prusa3d , everything works smoothly…the motors respond via the Repetier-Host program & the screen shows correctly the English characters and the menus to navigate!
Can anyone please help me resolve that issue…?
Thanks a lot in advance :wink:
Need to edit the firmware for that screen. Open the Arduino sofware, then tab over to Configuration.h
Find this part, waaaay down towards the bottom;
//======================== LCD / Controller Selection =========================
//======================== (Character-based LCDs) =========================
// RepRapDiscount Smart Controller.
// http://reprap.org/wiki/RepRapDiscount_Smart_Controller
// Note: Usually sold with a white PCB.
//#define REPRAP_DISCOUNT_SMART_CONTROLLER
Change that last line to;
Then a little ways down from there find;
//======================= LCD / Controller Selection =======================
//========================= (Graphical LCDs) ========================
// CONTROLLER TYPE: Graphical 128x64 (DOGM)
// IMPORTANT: The U8glib library is required for Graphical Display!
// https://github.com/olikraus/U8glib_Arduino
// RepRapDiscount FULL GRAPHIC Smart Controller
// http://reprap.org/wiki/RepRapDiscount_Full_Graphic_Smart_Controller
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
And change the last line to;
//#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
After that recompile the firmware and upload it. Should work.
THANKS a lot @Barry, for your lightning fast response to my problem here! :smiley:
I followed your instructions above, which were very well written & easy to understand :wink:
It worked!!! :slight_smile:
Sweet!
