I really like the this design and assembly went well. All the parts came from V1. Running the minirambo with LCD.
When I plot the crown with the laptop connected it comes out great. When I use the same gcode on 2 different flash cards this run amok with strange lines on the x and y. I used Ryan’s gcode on all 3 tests.
Have you removed the card while the LCD is powered? I have fried a card that way, try to reformat it with fat32. It might work. My lcd is very picky I use 4gb cards or less.
Josh and Ryan;
Thanks for those hints - I just completed my build - made a housing myself and before I read this thread, I had cleaned up my wires/cables in the housing to ensure I didn’t have too much bundled together. I also like the remarks about size of SD card and I will now place a Post-It to remind me to power down before removing the card - as well as place the card in before power-up.
Good stuff!
I am having complications with my MS SurfacePro recognizing the LowRider2 to enable the Repetier Host to connect. The COM port isn’t found. So I have yet to test the CNC with the crown drawing. I recalled too late yesterday to use the SD card - so I will need to try this route and see if it will comply. My goal is to run off the card anyway - to keep computer away from the shop as much as possible - so the quicker to the SD card the better.
