the problem is i am using a laser who is driving by the fan0 whit M106 and M107
but this new version of firmware have a little bug on the fan when send M107 it still have 2.5 volt on the fan port and my laser do not closed !
i look everywhere in the firmware and dont find where to change something to get 0.0 volts when i send M107 !
i hope my question is not to complicate and is clear enought !
The fans are low side drive. Meaning the positive is always 12V. The negative side is either shorted straight to ground (ON) or floating. When they are floating, there is a small led and resistor that pulls the pin up to 12Vish. 12V-12Vish could be 2.5V.
Do you still measure the 2.5V when the laser is disconnected?
hi jeff
i understand but i just check again and i have 6.32 volt with noting plugs on the fan0 on m107
if i plus the laser on it go down to 3.25 and not closing off
it must be the board i think and the green led is still on also but low yes it work in the past i made few thing whit laser and it was working perfectly
hi jeff
i used them all start from the beta one and it was working good and now it is bugging !
i order a new board i will recived it tomorow i will see if it is the board or not !
i will try to changed the board tomorow and i will see if everithing is gone to normal and if i dont i will try it
and i will also lower my power supply to 12.2 volts it is at 13.1 now
there is no way to change on the firmware something to get 0 ground on fan 0 ?
i could have bust the board or the laser controller i had it plus wrong side and it start doing this after i will se by eleminate the board first and regularised the power of the power supply i give you news tomorow
HI JEFF finally i putt a 5.1k and voltage drop to 0.04 and laser is off !
i realise in the new firmware they disable the laser fonction and they change command from m106/m107 to M3 M4 AND M5 if i read good i will have to configure it at least i will try they have a link
in french we say oh lala for meaning wow an other challenge
i am informing you of the change from new version
nothing work anymore now the m106 dont send any control to the fan 0 !
question tell me if i am right or wrong
since version 503 the fan port 0 was active for the laser for the version V1CNC_SkrPro_DualLR_2209 ?
