Hello and greetings from Finland!
I am trying to generate gcode from Fusion with guffys post processor. For some reasons Z feedrate in gcode seems to be the same than with X and Y, in my case 720mm/min (cutting rate from fusion feed&speed) . So neither the Travel Speed Z option in post processor nor max Z feedrate in Machine Kinematics in Fusion are working. They both are set below 400mm/min. This is my first time trying to create gcode straight from Fusion so I cant tell if this is something to do with the newest Fusion update or what. Plunge speed limit seems to be working but it only limits plunge moves. Anybody having the same issue? Or is this even anything to be concerned about?
The other issue I’m having is that the first move from machine 0,0,0 to entry position does not take retract or clearance heights into account and is dragging the surface. This is something I can fix manually by lifting the machine after setting z=0 but it’s against the idea I think.:D.
Also tried the other post processor, martindb’s, both issues appear also with it so probably Fusion is the problem?
I used Estlcam earlier succesfully but my current project includes a lot of difficult 3d shapes and various toolpaths so Fusion would be better I guess. If it worked.
