I have a problem with pronterface. I created a gcode using a estlcam and loaded into pronterface. It shows something like this in the console and there is no model showed.
The print goes:
from 0.00 mm to 0.00 mm in X and is 0.00 mm wide
from 0.00 mm to 0.00 mm in Y and is 0.00 mm deep
from 0.00 mm to 0.00 mm in Z and is 0.00 mm high
Estimated duration: 0 layers, 0:00:00
After I start, it shows endless echo:endstops hit: and moves a bit in x, y then z like trying to home. I cant solve a problem.
I dont have endstops, used firmware from this site https://www.v1engineering.com/marlin-firmware/.
Thanks, I will try it. Btw I recognized that in pronterface i can move manually only in one direction, for example x+, but not x-, like it be endstop triggered. It should be like that?
