bonjour
quand je change l’echelle sur estclam ca ne reduit rien du tout j ne trouve pas comment reduir mon dessin?
merci
Lucien,
After you select the resize menu option you must then click on the drawing to select it. It will turn red.
Once it is selected, you can adjust the size.
Do not forget to reset your zero point!
Be sure to resize the drawing before creating your toolpaths.
merci beaucoup
