after i have finally done my first cut, i have a problem that i don’t know the solution of:
The y and x axis are not the same in Estlcam, Repetier and the machine:
-On the Lowrider, the x axis is the one with the bars, and the y axis runs along the table.
-In Repetier, they are the same but the x axis is mirrored.
-In Estlcam, everything is rotated somehow.
I ended up getting it to work how i wanted it, but it is just very confusing to work with.
Do you know which settings to change in the software?
You can also just swap your X and Y… that’s how my machine is setup, for some reason I liked X being the long axis
X along the table, Y along the tubes, and Z going up.
Your coordinates and picture would still match so your homing switches sill be ok.
This would respect the convention of how the 3 axis supposed to be positioned together and so match the softwares.
That might be what i have to do… But how can i do that in the firmware? Because i run the dual endstops on the table-lenght axis it would have to account for that.
EDIT: i found it, i opened it in platformio.
(Another question, i found the firmware with the dual endstops that i need to change, but it is already compiled. where can i find a version that i still can modify in arduino IDE? or have i missed something? I am not an expert in the whole programming world, but i managed to once compile a BLtouch firmware for my Ender 5 printer by following a tutorial, i know how to do the changes once i have the firmware in the arduino IDE (i think so at least). )
I found my mistake, but it is something out of this topic. I open a new topic so that it is less confusing for everyone as my original title does not fit anymore.
