Question about printing from SD
So i have the full graphic display, all looks good, but it has to be powered via usb for that stuff to work. so what the point of having the sd function of the graphic display if it has to be powered with USB? is there a way to run it without usb? want to try and make it standalone untill i get the dedicated pc setup for it.
It should work without USB. What are the specs on your PSU? The LCD unit will get power through the 12V/5A connection that also powers the steppers
I have the older 20x4 LCD. Powers directly off the RAMPS. I usually don’t have computer connected to my CNC, though I wish I could get this FlashAir card working, to make it easier to send files to it!
They do not need the usb for power.
