Are you out of steppers? I can only order two.
Can I order the Rambo set and add end stops later? Will using the full Rambo complicate the building without the stops? I just want the option to upgrade my machine if the need comes…
Thank you so much for an amazing project!!
Yes, only two in stock right now.
Sure, it comes with them.
Nope, but you will need to change wiring harnesses or edit firmware when you want to switch.
High five.
Any inkling of when you’ll get a restock?
I prefer not to sell steppers individually, I only stock them when I have an odd number for some reason.
Aha! I see. Thanks for letting me know.
