The documentation implies that of the X and Y axis, the X-axis be longer than the Y-axis. Is that correct? Should the longer axis be the lower level one? And the shorter Y axis be the upper tube? When positioning the footers, should the screws be on the outside (with the pointy trapezoid end facing each other) along the longer axis? Then the higher/raised tube would run parallel to the 4 screw holes on the outside. There are pictures on the web site with builds showing footers both ways, but those are all square builds, not rectangular. It seems like you would want the longer axis lower to reduce sway or movement. Hopefully, I am describing this clear enough. Thank you for any advice.
Fred
