Been reading lots and watching lots of videos and have a few questions and thoughts, I can be a little scatterbrain so will try my best here.
I am planning on being able to put a 4x8 sheet of plywood in and have this machine make all my cuts for me. The calculator is great for belt lengths and stuff
Is there a way to get the right amount of belt in buying the parts bundle for me to make a 4x8 build area?
I plan on using a spindle rather than a router mostly for noise, and hopefully save a little bit of weight, but how does the speed control for them work then?
I plan on using 25mm OD 1/4" wall steel for the non moving tubes to give it some weight and hope it will reduce chatter and flex, will also make threading rod in for supports really easy, will be on a 1"x2" steel frame.
For the two moving rods will use stainless 25mm od. Now the x and y, one of them will be really long, and the other just long at just over 4’. I have seen others double up on these, but that takes up too much room. Has there been any testing on how the long lengths really matter? And on that note, does it start to get to be a little bit much for the steppers? Would doing double conduit on the narrow axis help enough to make it not needed on the other axis, or would it be pointless to only do one? -
how perfect of a straight line and repeatable can I expect? Like if I cut the long way down two boards and then butt them up could I expect them to fit flush?
Why isn’t there more large builds? I see mention of them a fair bit, but other than a mention of plans never any questions or real concerns with making a bigger table even.
Any advice from past attempts?
Would it be possible to use it as a planer for a large surface too? Just not sure how, since this acts more like a 3d printer than a router table, I think? right? no?
Hoping to order the parts here soon.
Thanks in advance.
