So I just built a new MPCNC and this is one of the first cut’s i’ve tried on wood with it.
When trying to cut out the actual sign I was making though it seems to have wandered off it’s actual path and started cutting out next
to where it should have been.
I believe it’s because the x and y axis were not squared, I was lucky that it worked during the engraving into the wood but I wasn’t lucky when it went to cut the outline.
Does this sound correct to you guys ? I realize now I should have squared it before I began.
Anything else you can think of to point me in the right direction?
It has a pronounced angle so that would be my first guess. Hard to say, speed, that tiny knot, bit selection, machine size, all of that can play a part.
A couple other things I’d check would be the drivers/belts/pulleys for the horizontal axis as it looks like it skipped steps when it was doing the outline.
