OK. I downloaded the J files - 25.4mm. -
- Mostly_Printed_CNC_525_MPCNC__J-25.4mm__1__OD_.zip
Thanks,
WTB
Thanks,
WTB
The 1" stuff is for 1" stainless tube, not emt. Tube is measured on the outside diameter, pipe is measured on the inside diameter.
There are 3 different sets of printed parts C-23.5mm, F-25mm, or J-25.4mm (1in). The measurement is for the Outside Diameter of the conduit/rails/tubing. Please measure your rails before printing. 23.5mm fits 3/4″ EMT conduit in the US. Anywhere else you must physically measure first, some things are sold as Inside Dimension (ID) (conduit), or Outside Dimension (OD) (Tubing).
I was confused with your description of what the C, F, and J sets were for. For others like me, could you make that section of the doc a little clearer?
From what I have experienced, I bought 1" conduit thinking that the J plans would work. Nope. 1" is ID with an aprox. 30mm OD where the J plans need 25.4mm OD. So back to the store I go with my Calipers but I think I am hitting a dilemma where I only have 3/4 or 1" Conduit to choose from. Would it be possible to get some suggested/recommended materials for each size. I have also been scouring the forums but haven’t found anything yet.
Thanks
Shane
Common problem…
That is immensely helpful. Thank you.
Shane
